Check with your local bearing stockist ( BRT Bearings are the UK`s largest supplier of wheel bearing kits, and have 20 branches ) , and be sure to ask for an OEM quality bearing, NOT a budget, or "Value range" brand . Wheel bearing kits containing ABS sensors should have fitting instructions , or refer you to the vehicle manufacturers recommended fitting practice. Incorrect fitting of ABS components will both invalidate any guarantee , and send a false signal to your cars electronics which may cause a false reading or damage. Also check comparison price from your local motor factor , but please ensure you buy a Premium product as there is a lot of sh1t on the market . As a guide , look for NTN , SKF,FAG,TIMKEN,NSK,NACHI, INA, SNR , all of which are top quality products .
You can use the old bearing as a guide to tap the new bearing in . If you have a tapered roller bearing (I.E. It is in two parts ) , stick the outer ring (wrapped) in the freezer until you are ready to fit it , and warm the inner ring gently before fitting it on the shaft. Be sure to grease tapered bearings before assembling , but do not overfill as this will cause "churning" leading to overheating and melting of the grease and getting past the seals.
