techcareuk
- May 13, 2009
- Location
- Nr Wigan, UK
- S500L (2002) W220 / SLK230k (1999) R170 / SLK280 (2007) R171 / E320 CDi sport (2007) S211
Hi, I have a 2007 S211 with comand and factory fitted I-Pod interface with connector in the glove box, it has steering wheel and dash integration and I select AUX on the comand to switch to the I-Pod.
I would like to intersect (if that's the correct word....) the AUX inputs that the I-Pod uses so I can regain use of the AUX input on the comand by use of a manual switch or relay for connection to a DAB tuner so when the DAB tuner is powered it takes priority over the I-Pod.
Has anyone done anything similar or have any info on where the I-Pod interface/control unit is located as I prefer to not have to start taking the dash apart or removing the comand if I don't have to?
