W211 - suggestions for head unit upgrade?
Adamski151
North Norfolk NR11
2008 E320 CDI (W211) + 1999 R129 SL500 + 1978 Rolls Silver Shadow II
Hey all - just buying a Japanese import W211. Whats the latest suggestion for a new headunit that will fit nicely and have an aux to plug phone in, USB to charge etc.
I know there have been threads on this over the years but the tech keeps changing and improving - any recent users with good experiences?
Cheers!
Adam.
Cheers!
Adam.
Why would you want to use an Aux input?
All units you will be looking at will have Bluetooth streaming for music and telephone as well as Satnav plus on board storage for music files 👍
Answer - partly because I listen to Hi-Res 24bit files from my phone which bluetooth cant handle.
Several Bluetooth codecs can support 24bit files.
Eg:
  • aptX HD:
    An enhanced version of aptX, aptX HD supports higher bitrates (up to 576kbps) and higher audio resolution (24-bit/48kHz).
  • LDAC:
    Sony's LDAC codec can transmit audio at up to 990kbps, offering the highest bitrate among standard Bluetooth codecs, and supports resolutions up to 24-bit/96kHz.
  • LHDC:
    Another high-bitrate codec, LHDC can transmit audio up to 900kbps and supports 24-bit/96kHz resolution.
Cool
I used the LDAC on my old Sony VII but was unable (with old ears) to tell the difference myself (but as I said, old ears)
You'll be doing a speaker (and cable) upgrade as well I take it to hear the added clarity, frequencies and detail.
Cool
Well said.
As a flibbertigibbet who jumps between cars, the bigger sound quality issue to me, seems to be post head unit: ie. amplifier, cable and speakers, rather than the input.
So there’s a need to upgrade after the head unit, to capture high quality sound
That said, I always “plug in” to the Aux, purely to keep the phone charged
Err, aux doesn't charge.....
But I agree, cable and speakers are key components for optimal audio performance.
Just not for me cause of the age of my ears, albeit I do buy decent mid range earphones and headphones
Can't help on the OPs question on HU though
Duh, mea culpa. Yes, I'm plugging in to USB, not Aux, which opens up the whole CarPlay / WAZE / Spotify world as well, either through bluetooth or cable.
Cheers!
Adam.
Have you checked the globe box for an aux input? They should already have it
My 05 W211 CDI has an aux port in the glove box. I'm pretty sure that they all did. I wired in USB to the glove box by tapping the cigarette lighter and installed one of these so I could get Bluetooth. I picked one that specifically did not take calls as I just wanted music over Bluetooth but there are others that have microphones.
Unlikely on a 2008 W211. Although I understand it is not difficult to add on into the existing quadblock?
What do I know! LOL
Mine didn't have one
I reckon you’re reflecting the European market.
I’ve owned too many Noughties Mercs. (E’s, SL’s and S’s) to be certain, but my impression was that aux input was an option which could be missing, could be in the glove box, or in the central console (between the two front seats)
But whatever, go to buy one and you’ll soon see where it is on any given car.
That's correct. My 2004 W211 does not have an aux input in the glove box. I have instead removed the 6 disc CD player and installed a bluetooth box (audio and phone via BT) in the hidden compartment that housed it.
This^^ I went through that whole headunit battle and its just not worth it. When with cheap android headunit then an expensive Kenwood unit and still got constant static sounds no matter what I did. Put it all back to OE and fitted the Mr12Volt kit. Best and dare I say only audio upgrade for the W211 that has most fibre setup.
for mine I tried to do a better job but buying a used cd changer for £10 just so I can use the plug harness from it the hook up this unit and then plug it into the power socket of the cd changer. so no major wire splicing etc.
