davidjpowell
We have a E350 W212. Until recently it has been reliable. It is now becoming something of an annoying teenager and nearly as expensive.
It has spent 3 days in the garage for 'stuff', where one of the things I wanted to sort was the drooping rear. It has come back with bigger problems elsewhere, and a diagnosis on the suspension that I'm not completely onboard with.
The rear drops most times, but often just one side. The side can vary.
The garage pressurised the system from the pump, and it did not lose pressure. They have therefore diagnosed the pump, believing there to be a valve that diverts air to each side. I thought however it was a single pipe that went out to a valve distribution block splitting out to left and right.
Any suggestions?
Any suggestions?
