W213 battery replacement
105mad
Chesham
2020 E350d Prem Plus Estate
If I replace the main battery on a 2019 w213 350d, will it need to be recoded or is it self learning?
It's
Why is a 2019 battery being replaced ?
They do more than start it up 👌
My c207 dash would light up like a Xmas tree at times on a 5 year old battery .
Amps start a car , voltage runs systems.
Very common these days.....on many modern cars regardless of make. Car are much more power hungry and more voltage sensitive than cars from previous decades.
I would choose a genuine MB battery too.
Varta is German, Exide is American, I know which I’d prefer. probably all made in China though. 😆
my 2019 has been through two batteries, one covered under warranty, 2nd one not as warranty battery doesn't have warranty... ? in just over a year the first replacement died because some keyless module wouldn't shut off, software update and another new battery later been the best its ever been, even leaving it for a month car started on a trickle charger most of the time now.
My 2018/19 glc is on its 2nd AGM. 39,000 miles. Previous owner ,short school runs killed it.
Made to MB specs. They are not all the same.
I used to produce circuit boards for mercedes airbag modules , although most were the same by design, the ones for mercedes were always ran with high end components. Capacitors , resistors, rom chips etc etc .the process was at mercedes asking also, Fiat ones were basically cheap as !!!
Shame they don’t use high end components for the terrible AdBlue systems. 😆 An aftermarket battery with a five year warranty, for half the price, will do me fine.
So going back to my original posting, can I just disconnect the leads, replace battery, re-attach leads just like in the old days?
Yes you can, you may have to reset the windows and mirrors but that’s it.
yes it will work, best to get a battery replacement reset done though as the battery control module charges a new battery differently to an older one.
