Rocketdan
Hi all.
I have a W639 Vito that has the symptom of the clutch peddle being heavy after continuous high speed driving e.g. coming off a slip road where it is only heavy on the first press and fine on the second. The pedal sometimes goes back to being hard on the first press when finishing work after being left for 8-10 hours with it being fine when parking up. Not long after buying the van I had the brake fluid changed and didn't notice this problem before. Are the two systems connected and could the brake fluid change have caused this problem with air being in the system after being improperly bled? I've read on other non MB car forums when googling the question that it is normal and part of the design and others saying the thrust bearing is at fault. Previous owner had towed with the van so maybe the clutch is worn. Any one else with a W639 Vito have the same symptoms?
