Reduction consumption too high. I’m guessing that this means adblue or similar.Does anyone know what fault code P20F5 is? I have seen things online about what it is but not 100% sure
Could it be the nox sensor as I have an adblue malfunction message and like 400 miles left before it turns off?Reduction consumption too high. I’m guessing that this means adblue or similar.
Seems to point towards the ad blue injector being worn and spraying too much ad blue.Could it be the nox sensor as I have an adblue malfunction message and like 400 miles left before it turns off?
No, It appeared after 1/5 of the tank had been emptied. I refilled it once this error code showedSeems to point towards the ad blue injector being worn and spraying too much ad blue.
Have you added ab blue to the tank recently ?
@OneForTheRoadNo, It appeared after 1/5 of the tank had been emptied. I refilled it once this error code showed
It didn’t do anything. It said no messages for 1 second but showed the error and Engline light back on. The adblue meter didn’t go up though once I filled it up to full. I went on the workshop menu and it showed that adblue was full. I think it’s not updating cus of the adblue malfunction and engline light. I’ve got an appointment for a recall so I’ll wait till thenTry adding more and cycle the ign a few times waiting 30 seconds in-between tries.
