I have a 1993 W124 sedan with hydraulic suspension. I will repair the leveling valve and do not know which oil it is. Also searching for a gasket kit for the valve.
ZHM , available from your dealership , about a tenner for a 1 litre bottle last time I bought it .
Hydraulically operated soft tops on the likes of the R129 also use the same mineral oil .
Citroen use a very similar green mineral oil in their suspensions , could be used in an emergency, but you’d then be best to flush the system and refill with the correct fluid , I’ve read that it isn’t a good idea to mix them .
