Whistle
Howard
MB Club Veteran
Toad Hall
2018 C63 Wagon / CLK430 / A150 / VW Pink Floyd Golf Cabriolet
Ok gang ,
I have a whistle .... its been bugging me for a while now , i'll give you the symptoms.
The engine only does it under load ( ie driving ) , it doesn't do it when you just rev it while stationary.
If you accellerate , it can be heard clearly , it begins at about 1500 rpm , when you let off and let the car coast , it stops ....
I have lubed all pulleys , belts and what not , it is definately not that.
It isn't a stone stuck in a pad .
The general concensus is that it may be a pipe drawing air , but to be honest i have absolutely no idea where to start looking as it won't do it when the car is stationary .... :(
Any ideas ? It really is spoiling the enjoyment of driving the car ....
If it's when under load it can only be something either pressurising or having high air-flow due to WOT.
This means it must be either the exhaust or intake tubing. I suppose it could be the crankcase vent valve.
In english please ....
When I read the first line I though you meant YOU had a whistle not your car:D (oops)
It could be a blocked exhaust or leaky joint so only shows under power, also the intake is only under full suction when the throttle is wide open (WOT), so will reveal a leak or split pipe then.
I also wonder about the resonance flaps being jammed in the high torque position causing restriction when under fiull throttle.
It isn't when it is under full throttle , weirdly , when it is under full throttle the noise is gone .
Olly , i know i was saying it sounded like a beetle at the GTG , but now it sounds kinda different ...
Doesn't sound like i am going to be able to sort this myself does it ?
Sorry should have said , its on a 99 320 CLK .
Get your Mrs to hang out of the window recording the a video of the sound while you drive it :)
Will be a help knowning exactly what the sound, sound likes
we should have gone for a drive at the GTG as im pretty sure this is the normal squeely noise that a lot of the 320 engines make...
It sounds a little bit like when you whistle through your teeth ...
thats normal!!!
I could show you lots of 320's here with that noise...
Its something to do with the harmonic balancer but MB always just said it was a characteristic of the engine...
I honestly have not heard another car make a noise like this ...
I might have a trip to Ollys when i get a spare weekend , see if he could have a look at it for me .
