Right, my D6(III) for my E350 has arrived.
Back to my previous post about routing the cable from the fuse box "into" the car, I've had a look tonight, and the German instructions state:
Para 1 : As shown in Figure 2, mark the point at which the cable of the BRABUS ECO-PowerXtra must be routed. Drill the opening of the side cover with a suitable drill bit and then expand it to a diameter of 35 mm, to ensure a receptacle of the supplied rubber grommet. Please refer to the pictures below.
Para 2 : Insert the connectors (plugs 2-6) of the BRABUS power kit through the side cover opening. Please note the direction of the execution. Mount the supplied grommet to seal the bushing and fix the cable in the bushing with a cable tie (Fig. 10, 11). Please make sure beforehand that the cable length is sufficient to lay the plug behind the lower dashboard trim.
Para 3 : Route connector 1 of the PowerXtra power module above the module carrier into the interior of the vehicle, beyond the lower dashboard trim. When laying the cable, make sure that the red area in the cable is not kinked. Lay the cable so that it is not damaged by sharp edges or similar. can be damaged.
So, I've removed the fuse box cover and found the side cover (in Para 1), which pulls out nicely (getting it back in however is a total shite as all the wires it's holding in then move outward, so I had to jerry them back in with the side of a pallet knife.... :\
I've also got a replacement grommet (Para 2) on order as my kit doesn't have one.
The "fun" bit is Para 3, where it glibly states "route it into the cabin". The pic (below) implies you need to lift up the fusebox, which implies (from what I can see) removing 4 screws - 2 of which are located right under a lip and would therefore be a total **** to get at without a very short, 90 degree ratchet. The pic below clearly has the fuse box "lifted up"?
When I looked at my car, I could not see the hole marked with the arrow, presumably as it's at the back....
What do the collective think?
Also, it boggles how the previous owner got it OUT of their car, it's not a nice shaped connector, and I'm presuming yanking it back up the hole would catch something?
