tintinmt
- Feb 1, 2009
Hi, I have a 300TE 24v (M104). It has a long standing issue whereby it seems to hold back (I hesitate to say misfire) under load e.g. pulling from a standing start or going uphill. In common with many of these W124 running issues many parts have been replaced but failed to give a long term solution. The car has new plugs, leads and distributor cap & rotor arm plus coils. I have had the car professionally 'repaired' on three occasions and each time the cure works for a week or two and then the fault returns. This includes replacing the distributor cap twice in the last 18 months. Recently, after many tests were carried out apparently, it was diagnosed as a broken wire on the camshaft position sensor (repaired) however the fault is now back.
The fault only occurs at full engine operating temperature. It seems to me that the offending item is maybe being disturbed during investigations but then subsequently fails again.
Otherwise all is good
Any ideas please?
Any ideas please?
