Excognito
- Feb 21, 2013
- Location
- South East
- Mercedes-Benz W211 E320 estate; Volvo V70 R AWD Phase I with LPG mod.
It's my own fault - I tempted Murphy.
I have a Mercedes W210 E320 CDi estate on an 02 plate. After addressing a number of fuel leak issues when I first got it, the car had been running smoothly, albeit with a rather low looking engine coolant temperature gauge. Average mpg around 35-36 mpg on my daily commute; I recently tried to drive it like the archetypal little old lady and managed an average of 40 mpg over several days and several hundred miles. So ... I made the mistake of feeling that the car was running rather well. Which is where Murphy stepped in.
Travelling down the motorway at 80 mph ... did I say 80? I meant 70, course ..., I thought a bump in the road felt strange, then the little triangular light flashed, followed a few seconds later by a bang and slight disturbance in the force through my steering wheel. Yep, front right-hand tyre shredded. Tyre duly changed and journey continued.
However, when I stopped and turned the engine off, I noticed that the cabin fan was still blowing. Prodding various buttons and restarting / restopping the engine made no difference. First things first, I checked the fuses and none of the likely culprits stopped the fan, so I took every one out in turn. This didn't work either and the number of potential combinations discouraged me from doing further experiments. A bit of smartphone research later, revealed this to be a reasonably common problem and the only first-aid cure seemed to be to disconnect the battery - no fuse! (? What ever happened to Failure Mode Analysis and single-point failure evaluation? duh!)
Reconnecting the battery resulted in a plethora (*) of pretty lights, including two malfunctions to do with the braking system (ABS). Didn't seem to affect braking, so I carried on.
The next time, I left the car for about an hour and didn't disconnect the battery as I expected it to last for a couple of hours. Wrong. Flat as a battery that's Professor of Euclidean planar geometry at the University of Flatland. Ah well. After jump-restarting, the gearbox went into limp mode but restored normal operation after I turned the car off then back again a few miles later.
And then finally, I wound the window down to talk to a friend and it wouldn't go up when I tried to close it. I eventually managed to get it back in place by pulling it up whilst my wife pressed the switch. One of my boys then pressed the switch on the passenger side and the same thing happened ... (anybody know how to get blood stains out of leather seats? ) ...
Now, I happen to belong to the Biggles School of Correlation (once is happenstance, twice is coincidence and three times is enemy action), so I'm wondering if there is possibly an underlying cause for these problems (outside of simple old age). I can see that the battery disconnect/reconnect might have caused the later problems, but the constant fan issue was the cause of the battery removal and would seem to be a separate issue - it's just the coincidence of it occurring post tyre-change that makes me wonder if there is more than just coincidence at work.
Thank you.
_______________________________________________
(*) I've had a penchant for "plethora" even since watching The Three Amigos Three Amigos-What Is A Plethora? - YouTube
Thank you.
