MercS204
i thought the C220 and C250 have identical OM651 twinturbo engines? also if it does have bigger injectors would it be possible to upgrade easily or is it a MB job to update the ECU with the new part?
I've just had my W204 C220 CDI remapped at Ecotune in Glasgow.
I prefer a remap of the ecu over a tuning box as the ecu can be tweaked to suit on a rolling road.
I know all rolling roads will give a slightly different readout but at least you can see the difference pre and post remap. Here's the graph from Tuesday
http://i128.photobucket.com/albums/p170/Gogs_11/W204 Merc/7BC774F9-41DF-4D55-83D8-486AEEB09740.jpg
I think that injectors are the only difference.
In 250cdi the injector map there is values up to 120mg/stroke fueling level.
In all the other versions only 90mg/stroke.
90mg gives ~500nm, 120mg gives a ~ 600nm.
250cdi 4wd automatic
OM651 200cdi automatic
Maybe I do not understand you right, but there isn't anything particularly wise about this, it is only fun.
Would u recommend them then ( very close to me) , did they remove ecu or was it done through obd port
/QUOTE]good service ? I took mine to gad north in Newcastle and he didn't have the right connectors for my ecu ??? Mines is 2008 w204 220 cdi sport
