mdelfunt
- Nov 15, 2016
- Location
- Georgia, USA
- 08 E320 Bluetek 200k miles, 06 e320 CDI, 290k miles.
Hey team, need some wisdom on my CDI, 290k miles. Engine was running fine at idle, turned it off and then went to start it back up and it won't. Cranks over fine and comes close to starting (chug chug usually to till the starter drops out thinking its running but it never rully runs). It will do this as long as you turn the key off and on. Here's some data to start.
1) I was having a accelerator pedal issue prior to this. A long story but 3 times the car would simply leave me stranded and wouldn't respond to any pedal movement. Change the pedal and it would run up to road a while and do the same thing again. It's important to note that during these pedal failures, the car would start and run fine as often as you wanted it to. So this this symptom is a mystery and the one I was working on when the "no start" occurred but I can't say for sure that its connected at all with the current issue.
2) Only code on ECM is Camshaft sensor and is stored, not active. I changed the sensor already. I am getting the low voltage code because I've been cranking it so much; I keep charging the battery.
3) Watching the scanner real time data, the rail pressure is 450 bar while cranking which seems to be plenty. I don't have a pressure gauge that goes high enough so I'm trusting the rail pressure sensor data. I cracked two fuel lines next to the injectors and fuel is coming out so my assessment is its not a fuel problem. I can see the fuel regulator % on live data going up and down.
4) Its cool outside but not really cold so my thinking is that any sort of glow plus failure would not prevent it from starting. However, I see where people argue this point; some say it will, some say if won't. I have a Mercedes shop manual that list glow plug system failure as a reason for not starting. I'm not sure.
5) I have not changed the crankshaft sensor. I read where people say this is a common problem in not starting but I'm not getting any codes. I've read where the Cam and Crank have to be in sync, makes sense but not sure if this is the issue. My scanner attempts to show me this data but its hard to understand. I can see "not initialized wait_inc", "Initialized Interims", "Initialized resync_overflow", "Initialized verify", "Initialized wait_phase", "Initialized polling" flashing on the screen during the cranking cycle; not sure what it all means.
6) My scanner is a Launch and does fairly extensive scanning but its not a Star. I can see a fair amount of live data and move actuators.
So I don't really know whether the original issue with the Pedal and the engine not starting is connected but its tempting to connect them. I've been approaching the no-start issue separately and simply looking to understand the fundamentals of getting the engine to start and then address the pedal issue after that. Here in the US, there are not as many diesel owners and information on forums, and experienced mechanics is limited. I'll be out in the shop all day today working on this issue so I would love any wisdom from people with experience. Thanks so much guys.
Mark
Mark
