spiderlane
- Dec 11, 2013
- 1986 r107
Hi all,
I have just taken our 1986 r107 with the m103 engine for MOT and happily it passed without advisories. The tester said that the emissions were right on the limit and that the car was running rich.
The car starts, idles and drives perfectly smoothly and I haven't noticed poor fuel consumption, but I'd like to understand if there is an issue.
I've read up on diagnosis via measuring the lambda on/off duty cycle on the X11 connector. I used my oscilloscope to measure the DC as follows.
1. Ignition on, engine not running - stable 69.3% (was expecting 70% here from my reading so this seems correct)
2. Engine idling, fluctuating between 48.6% and 49.6% - this seems to be about right indicating that the system is adjusting the mixture correctly according to the values from the O2 sensor.
So my question is - are the idling values correct? And does the idling value range indicate a very slight rich mixture? Should I be looking to adjust this to oscillate around the 50% value?
I look forward to any guidance.
Cheers
Mark
Cheers
Mark
