hello all,
I had an issue whereby I needed to replace the door lock actuator on my w204 c class rear drivers side door. it now opens using door handle inside and out but the central locking does not lock the door. the actuator makes a buzzing sound when you hit lock or unlock, have I installed the lock in the locked position and now it cannot get to the right position or does the car need to be programmed because there is a new lock?
