2013 CLS SB Rear Acreen Washer Nozzle
E55BOF
Hardcore MB Enthusiast
South Bucks
CLS63 SB, ML63, CLK350 'Vert, E350 Cabrio, Triumph Sprint (Bike not Dolly...),
Can anybody tell me how to get at the rear screen washer nozzle (just above the third brake light) on my 2013 CLS SB? I'm only getting a dribble rather than a spray, and I've tried giving it a good blast with an airline (worked on one of my 211s), but it hasn't cleared it. I'd like to be sure it's not a nozzle blockage before I do anything else. And no, it's not low fluid in the reservoir at the front.
Have you checked the voltage at the pump - might indicate a partially broken wire.
It runs at the same speed as the pump for the front, so I don't think that's where the problem lies. I suspect access will be by removing the interior trim, but I don't want to break something by tackling it with brute force and ignorance...
I have trim remover tools; what I don't know is where to start with them...
In 2019 I’ve changed the rear screen nozzle on my S212 after watching this video made for GLK. I doubt that the trim removal procedure for CLS SB is much different if at all.
Hi, did you work out how to do this, I need to do the same. Thanks
