amazighman
- Apr 22, 2016
- CLK 430
Hi fellas.
I have this old 2004 W211 with 722.6 transmission.
The issue is it has a slight slip when going from 1st to 2nd , worse when cold ,less noticeable when warm.
Basically as you pull away the RPMs go up as they should till 1800 then they drop suddenly to 1600 with a slight jerk , then pick up again and then gear change happens into 2nd .
Changed fluid few times ,its red and clean..
Changed valve body with good 2nd hand
Changed transmission filter.
Pan was clean no metal shavings or sludge
Fluid level is spot on.
No faults on diagnostic
I ran out of ideas
I ran out of ideas
