Alex225
- Aug 23, 2015
- CLS63 AMG
I thought since it's a dry day, I'd give the E a bit of tidy up since the harsh weather hasn't quite hit yet.
The car had done about 1,000 miles since the last wash so was in need. Started off with the wheels. Quick spray down with Autoglym Clean Wheels. I don't usually opt for wheel cleaners but had this left. Quick spray on, brushed and rinsed.
This is before I started. Not bad but not clean enough.
I decided on Dodo Juice products being the order of the day so gave the bodywork a once over with the usual two buckets, microfibre mitts and their Basics of Bling shampoo.
Once cleaned and dried, I opted for a once over with Need for Speed. This is essentially a polish that leaves behind a layer of Carnauba wax.
Despite the being able to use NFS as a stand alone product, it does leave a nice finish for a wax to be applied. I have a couple of 30ml panel pots of Dodo Juice Hard Candy so gave the car a layer.
You'd think with the car being pretty big and the pot of wax pretty small it wouldn't last, actually there's still plenty left after a coat. I'd genuinely expect another 3-4 coats out of a pot.
Finally the wheels received a quick layer of Red Mist, which is a spray on sealant. It lasts a few weeks on paintwork but held off applying it to the freshly waxed panels.
So here you go, a shiny protected W211!
Added a little window clinger as well, since it was quite fitting!
Just about had time to give the other half's CLS a clean before the light eventually vanished.
