A124 window regulator.
Merryhill
Shrewsbury
W124
I have a 1993 A124, and the rear driver's side window regulator has stopped working. Does anyone have any suggestions on how to obtain a replacement? They appear to be as rare as hen's teeth! Many thanks.
If it's just the motor that's died they can be swapped with one from a normal regulator.
If this has happened after the car has sat for a while, you can sometimes shock them back to life with some extra amps if you know what your doing.
