Andythegriff
The AC on my 2011 GL350 Blue Efficiency doesn't get cold. Everything appears to be working fine, have checked the air temp sensors etc on my icarsoft and nothing appears to be wrong. Its never managed to chill the incoming air at all since i have had it and running the system for 15 mins + makes no difference to the air supply temps in the car.
The local garage has re-gassed the system. They removed 750g of gas and replaced it with 950g. Vacuum test etc all past ok with no leakage. The icarsoft shows a system pressure of 6.5 bar but i don't know where that is (pre or post evaporator etc). Checking the function on the icarsoft also shows that the duty on the compressor is also being at least requested of correctly...100% on full cold and if i switch the AC off it slowly drops down as per the control functionality.
Any thoughts or ideas on what it could be or any ideas on how to check things physically/manually to see if things are working before i open up another can of worms with the local mechanic...i saw a vid on you tube about potentially collapsed compressor pipes but wasn't sure if that was applicable to these vehicles?.
Thanks very much for any help
Andy
Andy
