ALFAitalia
- Feb 19, 2022
- Location
- Bognor Regis
- 2010 Mercedes W212 E Class E350 CDI Sport, 2006 Mercedes W169 A Class A170.
At both the places I've used in recent times, their machines have done both a vacuum and pressure test..... its just part of the fully automated system that their AC machines use.Not sure many actually test with air pressure, usually they use a vacuum test which can mask a leak.
Then I get a little printed piece of paper that shows the pressure and vacuum tests, how long on each, how much refrigerant and oil they removed and how much they put in. Always get this slip if you can so you can check they put in the correct amount...some machines have outdated info and don't fill with the correct amount....as was the case once with my ALFA...too little. Although the machine does say how much its going to fill with before its starts.....ask what it says before they start so you can check on your phone that it's correct
