MJJ
- Jan 13, 2020
- Location
- Wiltshire
- '09 S211 E220 CDi manual - 197k miles and counting
Hi all,
I suspect a leak in the N/S rear airbag of my '09 S211 - quite a small one I think as it does take a good 5+ days for the suspension to drop. No dash warnings, and the compressor happily restores ride height when the engine is started. Car has rear air only (not Airmatic) and has 180k miles on it so I am doubting the bags are original.
I want to confirm a leak before simply replacing the pair, but am struggling to find a way to do that effectively. Car is on axle stands with the rear wheels removed, thus the suspension is at full extension and under no load. Additionally, the airbags currently fitted appear to have a rubber gaiter over the actual spring bag, so soapy water is just testing the gaiter. I don't think the bags are OEM as the part numbers on the bags don't tally with anything Mercedes part number wise in EPC.
Any recommendations or tips? Do the bags need removing from the car, inflating somehow (I have a compressor), then put into a large bucket of water to test?
Also, any recommendations for replacement? I am tempted to choose Arnott, but will see how much the OEM part is first.
Thanks,
Martin.
If it matters, these are the bags fitted to the car. Part number EK781606M/R815006000 only tallies with used parts on a Google search.
Thanks,
Martin.
