Air Pump
Ian B Walker
Freckleton
300-24, saloon and coupe, E300 24 valve diesel estate
Err cough > I need to ask another embarrasing question. :o What does the air pump on a W124 do exactly?
Cant help you with air pump
but website looks awesome. It even works properly on mac's safari.
Good luck with pump though
Regards Voya
Blows air down the exhaust to stop the cat being poisened when running rich after a cold sart.
Also I'm not sure but it may force the mixture to go rich due to the excess air passing the lamda sensor.
Oh, and it usually makes a nasty clanking noise.
I noticed that ;) goes away after a moment or two. Scared the hell out of me first time I heard it. :D
As Dieselman says; it helps to protect the catalyser on a cold start and I'm told reduces emmisions until the engine warms up sufficiently.
Until recently, (see other thread), mine made subdued chuffing noises as the pump did its job for a couple of minutes when starting from cold, then the thermostatic clutch built into the front pulley disengages the pump but the pulley still rotates because it forms part of the fan-belt route.
I'm told that not all cars had the pump fitted and I did consider changing all the brackets over to dispense with the pump, but as ever it's more complicated than it appears at first and entails changing the front engine cover; hence I'm looking for a reconditioned unit.
Still, as people at work have pointed out, my Merc is still quieter than their cars even with a rattling pulley!!
