Hey Guys
First I would like to apologize in advance for my bad writing - I´m danish.
I recently purchased a 2008 ML320cdi with airmatic. The car has 380.000km on it, a bit of rust, but I thinks its amazing
The problem is the airmatic, the car is sitting 3cm lower on the right side - front right and rear right. The struts are not leaking, since this level is constant, even after a week. I have tried to do a suspension calibration using the Maxidas DS808, and each corner can be lowered and raised without problems. But when I try to finish the calibration, I get a "Level calibration not successful". Before I started pushing buttons, the car did not have any airmatic faults, now it does. Can't really find the correct sensor values online, have only found for a MB wagon, which have 3 sensors only.
Values from each sensor before the first calibration :
Front Left : 3,08V
Front Right : 1.96V
Rear Left : 1,78V
Rear Right : 2.61V
Values from each sensor after the adjustments, car is now level all around :
Front Left : 3,24V
Front Right : 1.41V
Rear Left : 2,12V
Rear Right : 2.55V
The voltage from each sensor have to be within a specific value, for the scanner to accept the calibration, correct ?
Does anyone know this values ? Have seen a tread with a E-class, where is were 2-3Volts.
I have also tried to adjust each sensor to 2,5v, but the calibration still can´t be completed.
Do I really need a Star scanner, or maybe see a MB dealer ?
BR - Mathias Nielsen
Front Left : 3,08V
Front Right : 1.96V
Rear Left : 1,78V
Rear Right : 2.61V
Front Left : 3,24V
Front Right : 1.41V
Rear Left : 2,12V
Rear Right : 2.55V
