E552004
RHD 2004 E55 Japan model. Never seen road salt. Mint. Amazing PM from previous two owners.
Sanity check.
Ok so I changed the rear airbags to new Arnotts. Turned on car no automatic fill. Found a fuse. Changed, turned car on all air bags raised automatically. Yea! (No Ebay purchases from Asia.)
But the dash indicator with up arrow on the display? Car is up drives nice no leaks all happy. Dash up arrow with car still there? Check for codes. (Foxwell 510 elite). No codes. Only AC needs a recharge.
Changed the rear level sensor, changed airmatic valve block. No Change. Purchased a used Airmatic module same part number. Put that in. No change Still up arrow.
UP switch on shift console goes immediately red when you turn the car on and will not flash. You can turn off the switch and the light goes out but never flashes. It never did this before I changed the airbags.
I only changed the rear air bags because the dust boots had worn and were allowing dirt into the original airbags. Before that I had never seen this up arrow on the dash before. The airmatic system worked perfectly. Still does but can't live with this indicator saying malfunction.
Wakeup function through scanner looks turned off. Can't seem to turn it on? It's supposed to be on correct?
Sanity check.
