flying banana
- Oct 20, 2014
- Location
- Chilbolton, Hampshire
- ‘18 AMG GTS Premium - Selenite Grey, '99 Lotus Elise S1 111s - Mustard Pearl
Hi all,
Apologies for the long post.
My GTS (purchased used in january - from a non-MB/AMG dealer locally) Has developed a transmission issue and my local MB dealer has diagnosed a clutch control clamp issue and is recommending replacement, which is a transmission out job, requiring specialist tools, and the estimate is over £11k including VAT.
Before going ahead, i thought I'd ask around for a 2nd opinion based on the symptoms and what I know regarding fault codes.
Relevant Fault codes:
Motor Electonics MED1775 - CODE u010387 - Communication with the electronic selector lever module has a malfunction. The message is missing
Direct Select interface - Code U119887 - Communication with the intelligent Servo Module (ism) has a malfunction. The message is missing
Electronic transmission control for double-plate clutch transmission - code 061B00 - the torque calculation of the control unit has a malfunction
Symptoms:
When this first occurred, turning the car off, opening/closing the doors, locking the car and leaving for 10 minutes normally resulting in the remainder of the day being trouble free. I can tell when the transmission is happy as it will upshift in comfort mode at about 1600rpm nice and smoothly. When unhappy, upshifts occur at just over 2k rpm. Occasionally if I put the car into manual mode it will shift ok, albeit with fairly rough even gear changes. There is no change in gearbox NVH (except the rough changes, no whining, no sign there is an issue until it occurs.
My questions really are:
Options as I see them are:
So - thoughts please:
Do i trust the MB dealer and MB Technical who have diagnosed £11k\s worth of repair, or is the problem likely to persist once the work is done because the mechanical symptom isn't the root cause, If I do go ahead whats the best option for minimising cost - MB goodwill plea, upgrading warranty limit on the fly, seeking legal recourse for costs from the supplying dealer, etc.etc.
When it's working, the car is truly awesome, Ideally I'd keep it but for obvious reasons my trust in AMG engineering has been a bit dented.
Thanks all, and apologies again for the long-winded post.
Symptoms:
- Car starts normally, no error messages on dashboard
- Put the car into drive (comfort mode) ok, 1st gear selected
- Depress throttle pedal and car pulls away no issues
- On the first 2nd gear upshift, either it will go in fine at just under 2k rpm, or the shift will be extremely harsh, which then results in one of two different outcomes:
- There will be a very significant vibration (like a manual gearbox in too high a gear with the clutch out) followed by:
- Two or Three error messages flashing up on the dashboard
- Yellow Damper symbol and "Malfunction - See Owner's manual" message
- White "Electronic Rear Axle Differential lock inoperative" message
- Red "Reversing not possible - consult workshop" message
- A buzzing/grinding noise from the rear of the car
- The transmission putting itself into neutral
- Occasionally the “Park” button indicator lighting up whilst the car is still coasting
- When the red message pops up, the car will continue to drive, but in 1-3-5-7 only, with commensurately longer shifts, which occur at about 3k rpm.
- Or, The transmission will continue to upshift, with the shift to each even gear being harsh, and downshifts into even gears likewise. If the even shifts are rough, I know it will throw the dashboard errors at some point, typically a few minutes into a journey.
- if its a mechanical component issue, why does power resetting the car resolve it, and
- Which is the chicken and which is the egg - are there electical/electronic gremlins causing the gearbox to get confused and upsetting the clutch control on the even/reverse gearset, or is a mechanical issue on the even/reverse gearset causing the electronics to get confused?
- Stump up the £8.3k (without tools) to have it fixed, using the 3rd party warranty I have to cover the first £5k, and/or
- Seek some goodwill contribution from MBUK on repair - the car is 6 years old, but had only covered 37k miles when the issue arose - low mileage for a gearbox mechanical failure (although I don't know whether the car was misued and abused by previous owners)
- Speak to the MB dealership who have the car to enquire about the option of having them buy the car from me as-is, and take a substantial bath on what I paid.
- Go back to the supplying dealer with a sale of goods argument, requesting that they foot the reapir bill, or give me my money back less allowances for additional mileage whilst in my possession.
