500E said:Could that be modded to fit 500E or E55 (W210)?
nigel cross said:It seems strange to me that if it was a rear ender, so the front was ok, how come this was removed from the engine, unless that was totalled as well. It also seems strange that he has no other parts, however small to sell.
Perphaps its just me being over cautious, Buyer Beware.
:bannana:
andy_cyp said:Is the s/charger in a cl 55 the same as the one found in the c32 ????.
would be a nice mod if fitments were the same but added a few more horses.
stats007 said:Put it this way - Kleemann want £12k + VAT to fit their supercharger to my car. They do do a V6 version which may be cheaper!
Kleemann Kompressor
I believe the C32 AMG has strengthened internals to run the supercharger - con rods etc even if you could just plumb one in and change the ECU.
Thmsshaun said:Hmmmmmmm more power. more power. Would it fit a C43![]()
esox said:"This very high performace forced induction supercharger which is hand built in germany stuttgart can also be used in project cars but it is hard to do. In the berkshire region i am confidant that it works i would even fit it for £500. "
Fit it to what?
The only thing it`s suitable to be fitted to is the car from which it came...
The blower is only one part of the system - think of all the dozens of other parts that a supercharged AMG has that a "normal" V8 does not.Air ducts,MAF sensors,ECU,intercooler etc etc....The intercooler alone would be more than the £500 he says he can fit it for.And then the engine itself,a blown AMG probably has uprated crank,rods pistons......
Its not simply a bolt-on Max-Power accessory....
