fred_raven
As all of you regulars will know - have had several faults recently now only a leak to sort
Have had the water pump changed ( by mechanic) , I changed the Duovalve ( easy enough) . BUT now have a leak, losing around 1 litre per day ( around 200 mls)
Am pretty sure its not from duovalve area , no signs. Cant see anything around water pump, but could be coming out from underneath ( hidden by lower cover ) or maybe the heater matrix ( did make LOUD gurgling noises when lost water when pump went .
But even with this amount of loss i cant see anysigns of a leak - any ideas how i can track it down. I read that leak sealers ( barr's ) arnt good to use - any that are ok if i cant find it ?
