Anyone have the WIS sheets to remove the Fuel Flap Actuator?
Brian23
2005 E200 Estate
Hi does Anyone have the WIS sheets to remove the Fuel Flap Actuator?
2011 E200 Estate.
As the photo you would expect to just remove the 2 screws on the old one and pull it off, but where it is you cannot seem to get to the screws, so if anyone has the WIS removal sheets it would be much appreciated.
I guess this is one of the topics that WIS considers obvious for a mechanic (while at other times instructs how to use a screw driver). After a quick search I only found instructions to remove the complete tank recess where at one step the central locking bolt guide is removed by turning it first 90 degrees.
Someone must have done this for real and will hopefully help you soon.
Yes you would think, but also you would think that someone would have the service sheets for this. I will just have to leave it unlocked as I had to break the original motor locking pin off to get in to re-fuel.
Do you mean someone might have WIS sheets that are missing from my copy?
