Anyone know what it is
Air temp sensor. Barely works and has no affect when disconnected.
Slightly worrying if its covered in oil? You may have an oil breather pipe from the engine connected to the adjoining pipework (not sure of your models inlet plumbing :confused: ) and this could be the source of the oil = vapour from the crankcase. As BlackC55 says its not too important- you could try cleaning it with solvent BUT if the oil vapour was to reach your MAF sensor -item 5 that would be a different and more expensive story!
