Assistance Please
pstock
Ashford Kent
W212 E63s
I require the wiring diagram for the doors on a CL500 (MY2001) both passenger and drivers.
Could anyone point me in the right place.
Thanks in advance.
Paul
Thanks but its not my car !
Another CL500 owner in my home town has this problem, he has replaced the damaged broken wires and still nothing functions on his drivers door mainly needed to find where power is fed from, Fuse number and so on..
Pretty sure drivers front Sam, under the bonnet (fuse box) has the thick live from the drivers door going into a snap connector underneath it, so would need to remove the complete fuse box to check, you may even have water Ingres in this unit this is also common.
Check feeds with a multi meter to make sure you have a good grind/12v feed
