Hi guys. New owner here. Just posted in the welcome section.
Wonder if i could have your thoughts please.
I have an E270 2004 W211. It appears to have the Audio 20 set up with a single cd slot below the display and a built in cradle in the armrest. I have given my VIN to the company that deal with Viseoo and they say i need toe mbu 3000 (if that helps you all).
Anyway what i am after is the following:
I want a bluetooth connection that i can use for calls as well as streaming music from my Galaxy s7 Edge. I would rather, if possible take out the fitted holder in the armrest. I'm not interested in SatNav as i use my phone for this. As a single working dad with 4 teenagers living at home cost has to be a consideration for me.
From the searches i have done it seems i have the following options.
To replace with an Audio 20 from 2009 onwards. These units are going for a lot at the moment so cost is a little prohibitive.
To put in an aftermarket head unit. This seems to be the most complicated option.
To remove the current stereo and solder an aux adaptor into it and then use a bluetooth adaptor through this port
I'm fairly ok with tools so would be happy to have a go myself.
For those of you that have experience in the Audio side of the car what are your views and advice as to the best way forward please?
Thanks, Steve
Thanks, Steve
