i have a clunking noise from the rear axle hen it changes gear. it is more pronounced when it is cold and when not accellerating. When under pressure it appears to change smoothly. Other threads suggest that an oil and filter change may be the answer. The car has done nearly 200k miles and the flexible joint in the prop shaft was changed very recently. Any indications as to cause and cure? Many thanks
Anthony
Anthony
