Hi All
At the MPH show at Earls Court, I picked up a product called autolights. It's a self install bit of electronics with a sensor to automatically switch on lights when in a tunnel/dark areas etc. It takes power from the ignition switch and you need to tap into headlight and sidelight wires. You also need to position the sensor. My questions are has anyone done this before and if so where is the best place to make the aforementioned connections. With regard to the sensor, it looks like there is an ideal spot in the centre of the dash where it meets the screen. There seems to be a squareish plug that may even be for this purpose had it been done as a factory fit. It would be nice if the wire to the sensor could hidden, but I'm not sure how this can be done.
Any help or suggestions will be most appreciated.
