Scope of a service.
I think this is a list of all the service items on my car:
A Service
Check: Horn, headlamp flasher, hazard warning lights, turn signals
all bulbs, and warning and button lights and interior lights.
Check: Windscreen wiper and washer system.
Check: Tyre pressures including spare.
Change engine oil and filter,
Check coolant/antifreeze
Check Brake system, especially for fluid loss
Lubricate catch and hinges on the bonnet
B Service
Check brakes on a dyno or test drive
Check seat belts for damage and operation
Change air con carbon filter
Check battery fluid level
Rotate wheels
Check front and rear pads and replace if needed
Check front and rear discs replace if needed
Check condition of tyres
Measure tread depths
Check for leaks on major assemblies
check condition of poly belt
Check front axle joint for play, check boots
Check rear axle joint for play, check boots
Check tie rod and steering arm for play, check boots
Check power steering, top up fluid
Lubricate throttle linkages
Check headlamp range and adjustment
Every 18,000 miles adjust parking brake
Every 2 years change air filter
Every 50000 miles check flexible couplings
Every 50,000miles change fuel filter
Every 50,000 miles tighten securing bolts of steering column
Every 2 years change brake fluid
Every 2 years check bodywork
Every 3 years change coolant
Every 18,000 miles change spark plugs
