B200 Turbo Part Help
roheel
Hi All,
I’m after some help trying to locate a part that Mercedes have told me is no longer available and won’t be. Part number is:
A266150121864
It’s the ignition cable for cylinder 3. All the others are available apart from this one, which I find really odd. I have checked eBay and I don’t want to go down the 2nd hand route as it’s a nightmare to get to in the car if it turns out to be faulty.
At present the car is a write off due to a £60 cable!
Even though it gives Mercedes UK a price, they state it’s no longer made and will not be available to order.
Any advice please?
Won’t ship to the uk, I’ve asked. Plus over £100 considering it’s retail is £60
That's dollars....so about £80. Retail is a bit irrelevant if they are not longer available......but the shipping's a problem.
This is why I’m stuck. A perfectly decent car written off…
A little dramatic.
Why can you not get a lead made up? There are plenty of companies on line that can do this.
Can you recommend one as I’ve contacted a few and unless I want 100 made as a minimum, there is zero interest
Hi All,
A266150121864
Do non of the others fit? Surely its only the length of the HT lead being the difference between cylinders. Just buy a longer one.
Precisely. I thought of this but it seemed to obvious!
Have you tried here :
I will try in the morning, nothing on the website for the model.
Do Magnacore do a set?
So no luck, they are individually part numbered, where as the smaller engine ones you can buy as a set
