Back pressure sensor Location A180 1.5D 2013 Bluemotion
Hi Adilliqbal ,yes I did find the sensor its on the left hand side of the engine on the top and goes into a rubber pipe .It is held in place by a flat clip under the bracket .The rubber pipe goes on to a metal pipe which goes into the exhaust manifold , you might find the metal pipe is blocked with carbon , mine was I un blocked it by heating the pipe and connecting it to a air line to clear it . I had to replace the sensor aswell . The sensor is made by Renault as and is far cheaper than getting it from Mercedes £106 from them. I ordered a genuine Renault one off ebay for £31.45 , Ebay no 253958714774 same Part number number as the sensor on my Merc. My car is running and driving fine as it should with no further problems. Hope this helps you.
Hi I have found these comparable units so I guess they have the same 3 pin plug?
DACIA RENAULT
22 36 509 01R - 223650901R - H8201417034 - 8201417034 - 82 01 417 034
Hi to every one, new to the forum. I have a A180 2013 1.5d with fault code P0471 exhaust back pressure sensor Faulty Mounted and Faulty Signal .Could someone tell where the sensor is located and where to get one from thanks
I got this from a french website part looks identical to mine on mercedes a class
Références OE OEM Dacia Renault Nissan Opel Mercedes​
SENSATA
81CP53 01 - 81CP53 02 - 81CP5301 - 81CP5302
DACIA RENAULT
NISSAN
22760 00Q0C - 2276000Q0C
MERCEDES-BENZ :
607 905 26 00 - 6079052600 - A 607 905 26 00 - A6079052600
along with other cars it fits
I would like to concur with MAC1234: the Renault part plugs in fine. And I managed to clear the code on my reader. This part was 99 plus vat in main dealer. Will see how it goes as I didn't replace the pipe but on inspection seemed a clear flow of air and not blocked. I tried the tissue test with tissue paper but we use the dense luxury type and it wouldn't lift lol cheers Mac 🍻
DACIA RENAULT
Yes I can concur same connection three pin
Just when I thought it was safe to go back in the water code PO471 appeared again? New Renault sensor installed code was cleared can only think its the pipe blocked and nothing is reaching the sensor perhaps?
Just got mine from Mercedes genuine parts, not too bad on price to be honest, had dramas with the Exhaust Actuator Valve / Flap due to this problem and a P0545 Exhaust Temp Sensor issue. The following is a diagram of parts, potentially same car, with part numbers on if you can see or when speaking with parts team at Mercedes.
I presume the DPF temperature sensor on the Om607 A180 engine is just to the rear of the back pressure sensor
Did DPF regen replaced back pressure sensor multi meter giving me live at terminal.. Reporting on ob2 that its sensor circuit issue. Possibly relay?
A re-gen will not always clean the DPF. The bets way is to remove it and get it cleaned.
Thanks Guys, I've just posted a thread on this after going to a specialist. the BCU is showing a good airflow on pipe I did spray this with DPF cleaner as well. I am also getting a psi reading my end. They showed a DPF sensor fault that I didnt get on my ob2 and I think these are all false positives. Do I just go for a DPF clean with them to try and iron out all these sensor issues?
I have a B180 CDI (2014). Has come up with the same code PO471. The genuine MB back pressure sensor is on back order and unavailable (checked with two garages). I asked them to have a look at the connecting pipe having read about it being a potential problem on this forum, they say it does appear partially blocked but they were unable to clean it. In my mind if the pipe is blocked it makes sense to replace it, as there might be no error with the sensor and its only showing a code because it gets a different pressure from the blocked pipe. But they don't want to replace the pipe without replacing the sensor, I'm no expert so I wasn't going to insist.
Any idea how easy it would be for me to try replacing the pipe myself? The sensor is easily accessible, right on top of the engine. But the pipe goes down behind and appears to be secured with nut that isn't obviously accessible.
When you cleaned your pipe did you remove it first? I'm guessing you'd need to as you couldn't blast air and carbon dust back into it right?
By the sounds of your issue I could potentially replace both pipe and the sensor and it is still caused by an error elsewhere. The car does seem to have a bit more power to it since they attempted to clean the pipe, but I might just be imagining that.
Hi there, these are all false flags to be honest I finally talked to a DPF cleaning specialist and the garages are a complete waste of time on this they will just replace sensors and charge for diagnostics but from experience it doesn't solve the problem. Our a180 finally went into limp mode after having dpf regen done and the back pressure sensor replaced and the garage suggested there was good airflow through the pipe on their BCU. I was also reading good psi through on my home machine. They picked up DPF sensor fault on their system that I didnt. But again if blocked its going to kick back that anyway as it can't read what it needs to. So its going in to get the DPF cleaned by specialists then we will see what everything else is doing r not doing as the case may be:) This is the OM607 engine btw. A good tip from the recovery guy today was if the DPF is blocked if you put your hand on the exhaust it will stop the car, equally if the DPF is that blocked the car is going to slow down and eventually stop. What is clear is that the powers that be have completely screwed the diesel engine up as we know it and we haven't even got to bad blue yet lol.
PS if a 607 engine the bps from a Renault will fit from ebay 30 pounds
OK guys we got a conclusion to the back pressure pipe issue on our 15 A180 with tripe Renault engine fitted. There is no easy way to say this but its a 300 job or thereabouts. Trying to sort out yourself will only add to the cost. Essentially most garages run away from jobs on these 607 engines as everything is situated at the rear. Even the DPF Filter itself. Most garages diagnose DPF sensor back pressure sensors as faulty not the case. Once we had the pipe replaced they all cleared. I put new cheap Renault back pressure sensor on as the original had a melted tip and was full of carbon. So first thing you do is get the pipe changed and work the problem from there. Go to DPF specialist as well they read the output on the DPF Filter and it was fine again garages will charge 300 to 400 for this. And it won't solve the problem 😁
Sorry to revive an old thread but, Has anyone got an idea if 8200874421 and 820100764 are equivalent parts both are Renault numbers both also say H8200443536 underneath.
