battery drain2007 E220 cdi W211
Tubbasher
Nottinghamshire UK
2007 E220cdi AvantGarde W211
Hello folks I hope someone can help before I lose my sanity, my E220cdi 2007 w211 battery drains to almost flat after 4/5 days its been suggested the audio gateway control is faulty and is not going to sleep does anyone know where the fuse is and what number? thanks
Hello, on my 03 E55 the audio gateway fuse is number 6 located in the left side (as you look from rear) of the boot, behind a trim panel, when that small square panel is removed, you’ll see a black rectangular plastic cover, remove that and you will see the fuses, number 6 is a 40amp fuse. You may want to remove fuse 9 which is the overhead control panel 25amp, another known drain. It could also be the seat adjustment fuses 23&34 both 30amp located drivers side (uk) dash side panel, accessible when door open. That should give you some idea, although yours may be in a different location.
Hi thanks for the Info it gives me some idea were to start looking.
