Benz A class 2008
Herc1976
London
Benz A Class
Hi guys,
I just brought a Benz a class 2008 (150se),
Needs some advice to check the car.
What e
Hi guys,
What exactly are you wanting to check?
If I am not mistaken, yours is a W169 pre-facelift? If so check for rust around the doors - look behind the rubber door seals and also at the bottom of each door where the metal is folded back and welded. These areas are prone to rusting.
Start hear .
Search this forum for W169 or A class ect
Check everything electrical item is working 100%
FIRST CHECK , pollen filter drain is clear, check spare wheel well for water, battery box for water
Do you have service history, did you check old mot history ect
TEZZ
