Blackberry
Tan
Woodford Green
W140 S-Class, Porsche Cayenne and Porsche Boxster
Hi
My wife has a blackberry and wants to know if there is way to scroll to the top of the list of emails quickly rather than via the scroll wheel?
TIA
Tan
On mine if I press '1' (also E R) it goes straight to the top.
Amazing how many people I see scrolling away with the wheel to get to the top.
Forgot to say mine's a 7130. It may be different on the newer models
And another thing...
Mine is a Pearl 8100. If I want to send a text (which is rare), I say "Compose SMS", and it always takes me direct to the 'E's in my address book. I have to use the pearl to scroll to the top of the list, to get to [use once]. How can I jump to the top, or bypass this process?
If I press '1' it does nowt.
PJ
On the 8707g you press T
Yes, typical RIM absolutly terrible consistency from one model to the next.
Doesn't work on the Pearl, either for Tan's problem, or for mine.
Heres something I made earlier. (any reference to the half moon key means the ALT button as this was its reference on older handsets)
Blackberry hints and tips
ALT key = has half moon on top of it. left side of keyboard below the A.
CAP key = bottom right key (AKA SHIFT key)
In General
1) Hold the ALT key while you roll the thumb-wheel to scroll horizontally in any field where you can enter or view text.
2) Hold the ALT key while you roll the thumb-wheel to scroll through a field to view options.
3) Hold the CAP key while you roll the thumb-wheel to select multiple items in a list.
4) Type the first letter of an item in an options list or menu to jump directly to that item.
5) Type the first letters of a name or the initials separated by a space to find a contact in the Address Book screen.
6) Press C to compose a new message from the home screen or within Messages
7) Rearrange the ribbon: In the Home screen (ribbon), hold the ALT key and click the thumb-wheel to bring up a menu. You can then select Move Icon, Hide Icon, or Show All. If you hide an icon, to show it again click Show all and it will appear with an X over it, bring up the menu on it and uncheck hide icon.
8) On older 7290 handsets prior, the Blackberry display can be backlit to allow reading messages in the dark. To get the light to come on, hit the backlight button usually in the lower right of the keyboard. Hopefully you have a backlit keyboard as well so you can type in the dark.
9) Turning the radio off and back on when coverage is spotty and you've lost signal seems to help. Also going into network and selecting register now will help. And if you have a phone/combo BB then on some you can go into network and select Scan for networks. then select the network you are on, for example T-mobile, then save. After doing this the radio will reset and you may receive a register message and a new service book, which you can accept from the service book menu in options.
10) Password protect your BB. To set a password, go to the Options menu to the Security item. Set the desired timeout (I use 15 minutes) and enable/set a password. In conjunction with this, you should also go to the Options menu to the Owner item, and enter your name, phone number, etc. When the password protection kicks in, this is what is displayed on the screen.
11) After X incorrect attempts at typing in your password, the password starts echoing (figuring you really need all the help you can get). After ten attempts, it performs a lobotomy on itself and almost all data is cleared. The Memo database, however, is retained and visible.
12) To support more than one signature. Wipe out your auto-signature in the Redirector of the Desktop Software and just use 'AutoText' to configure alternate sigs.
In the Message List
(Some of these work in tasks, memos, and appointments also)
Sorting:
1) ALT-i: show only incoming mail
2) ALT-o: show only outgoing mail (messages you have sent - i.e. checkmark icon)
3) ALT-p: show phone log messages
4) ALT-s: show SMS messages
5) ALT-v: show VoiceMail messages
Navigating:
1) t: go to top of message listing
2) b: go to end/bottom of message listing
3) backspace: close message listing and return to home screen (ribbon)
4) spacebar: pagedown
5) cap + spacebar: pageup
Deleting multiple messages at once:
1) Highlight a date (i.e. Fri, Oct 05,2001) in the message list, hit the thumb-wheel and select delete prior. All messages prior to that date will be deleted.
2) Hold down the CAP key and use the thumb-wheel to scroll up or down to select messages. Click the thumb-wheel and select 'Delete Messages'. Combine this with a sorting tip to make it even more useful (i.e. To delete the last 5 messages that you have sent (checkmarks), press 'ALT' then the letter 'o' (for outgoing) this will show all of your sent messages, then per this tip scroll down and select the last five.
While In A Message
Navigating:
1) enter or spacebar: scroll down a page/screen at a time
2) ALT-enter or spacebar: scroll back a page/screen at a time
3) b: scroll to end of page
4) t: scroll to top of page
5) u: jump to closest unread message
6) n: jump to next message
7) p: jump to previous message
8) backspace: close message and return to message listing
Reply-to/Forward:
1) r: reply to or answer this message
2) f: forward this message
Select Text (OS v2.1+):
1) Press the CAP key and then scroll the thumb-wheel to select. If you release the CAP key and scroll the thumb-wheel you will select entire lines. Press the CAP key again at any time to start selecting by character again.
2) Hold down ALT key + CLICK the thumb-wheel (click it don't hold it down), release the thumb-wheel and then use it to scroll whole lines. You can press and hold the ALT key at anytime to start selecting by character again.
3) Click scroll wheel and select SELECT from the menu. scroll wheel to select entire line. click scroll wheel again and select copy.
With either method, click the thumb-wheel and select 'Cut Selection' or 'Copy Selection'... to paste, open a new message or whatever, click the thumb-wheel, and then select 'Paste Selection'.
Composing Message
1) Press and hold a letter to capitalize it (with Key Rate enabled).
2) Press the SPACE key twice to insert a period and capitalize the next letter.
3) Press the SPACE key to insert the "@" and "." characters in an Email field. Backspace and type again to over-ride this like you would with AutoText.
4) Press and hold a letter key and roll the thumb-wheel to scroll through international/accent characters, equation symbols and other marks.
Calendar (from Agenda screen)
1) Press T to go to "Today" in the Calendar screen.
2) Press G to go to a specific date in the Calendar screen.
3) The default date range for Calendar synchronization in Desktop Manager may not suit most people. While configuring the Calendar synchronization, click the Advanced button and specify the desired range.
Battery
1) The largest draw on battery life is the transmitter, so if you are transmitting a lot, you can expect reduced battery life. And the backlight.
2) Being in fringe or no coverage areas will eat up your battery as it attempts to transmit. If you're in an area that is out of range, turn your BB's radio off manually or use Options / Auto On Off to conserve battery life.
Geek Tips
1) Rather than looking at the bars, you can change the display of the 'signal strength' to read in real numbers. While at the home screen (ribbon), hold down the half moon ALT key while you type NMLL. The bars should change to read numbers. For the 'signal strength', if you are in the 100 area (that means -100 dBm), you will be transmitting at maximum power (2 Watts), and since coverage is hit and miss at this weak a signal, you may end up transmitting many times before the packets make it through. This might help explain any poorer than normal battery life. I consider anything at -90 to -50 excellent.
2) To get the bars back: While at the home screen (ribbon), hold down the half moon ALT key while you type NMLL again.
3) Hold down the half moon ALT key -AND- the CAP key at the same time, then the letter 'h'. This brings up the "Help Me!" screen that lists version, app version, pin, imei, uptime, signal strength, batterylevel, file free, and file total.
4) Hold down the half moon ALT while you type LGLG. This brings up the event log where you can clear events (frees some memory) or view them or copy the contents to mail to someone.
5) ALT-CAP-Backspace will reboot your BB.
Whats the first letter in your address book?
Usually it takes you there and you type in the name (not scroll).
It's "A".
Just wondering if your A's have numbers assigned or just emai addresses.
Thanks guys.... will go and test the Blackberry now.
My wife can't believe the number of responces that were recieved, she thinks we are all crazy.... in the nicest possible way.
:confused:
If that was a question to me, then the answer is both. All my contacts have numbers, and may have email addresses too.
by the way there is a nice tutorial on the phone itself under help.. it tells you all the shortcuts etc... i use the shortcuts all the time..
T for top, E for bottom (End), R for reply, F for forward, hold green for address book etc etc
and yes we are sad..
