Brabus D6 (II) instructions
Doodle
Echo Beach
Superb 365 wagon
Anyone got any or have an online copy? :wallbash:
I've tried mailing Brabus with no response, and every damn copy I can find on the internet is for the later V6 box.
Did the whole intuition "lay the loom out in the most obvious way and then hunt the relevant connector" method - no joy :doh:
It is very obvious. Give it a try.....
I did...the car gave me the metaphorical "What ARE you doing?" and refused to catch although it did turn over :doh:
Connections made:
One to the connection on the metal pipe by the airbox
One to the end of the fuel rail
One to the injector at the front of the engine.
Fuse connected to #62 in the fusebox.
Connector into D6 box.
To be fair, it started raining halfway through so I hurried (which was probably my error), will try again when it is better.
Hmmm, looking at a schematic I think I got the boost sensor hookup in the wrong place.
Right, boost sensor located, and it now fires. Fuse 62 contained a 30A fuse, which made me a bit nervous as the power line on the box is fused for 8...and you can't check what fuse is what because they haven't put a diagram in the engine bay fuse box!
However, EML is on...but this could be because I had to unplug the ECU to recover the bit I dropped inside the fuse box.
Probable? Otherwise something still isn't right :wallbash:
Sorted. It was my doing, quick blat with the code reader and it was cleared, test drive all ok.
Pleas schematic
