Braking lights gone alternately
Dennis
I have a 1995 C280.
For these a few months, I lived with indash LAMP check warning light. Finally, I decided to fix it and found that the high mounted stop lamp had gone.
So, I bought one from a local third-party part shop and replaced it, and then the warning light was also cleared. I was very happy with that.
Only 3 days later, however, one of the rear breaking lights is gone again. So I replaced TWO breaking lights at the same time. Then, the warning light was cleared.
Sadly two days later, the high mounted stop lamp went out again. I also found that the one of breaking light socket in the bulb holder is slightly melted down, probably from high heat.
I think there is some problem with the breaking lights system.
Will it help to replace the bulb holder?
I am also considering changing the whole bulbs in the rear with dealer parts.
Any comments on this will be highly appreciated.
Thank you so much.
2 Years ago I fitted my highlevel brake light, and did a dodgy connection with the passenger side rear bulb circuit.
This caused the bulb cluster to fail completely, it couldnt ever carry and current.
Only way I fixed this was by buying a new circult from Mercman (about £8 IIRC), maybe this is a help?
Thanks a million KillerHERTZ.
If the problem continues, I will try that.
Thank you again ;)
