Broken Plastics on the door, HELP
cmsound
Cyprus
E-Class W211
I have the E-Class W211 2006 and the plastics on my door have become very brittle. Any idea where I can get a pair to replace them, maybe from ebay etc. Also, what are they called?
Thanks in advance.
If you remove one of those fuse covers, post up the part number that will be stamped on it, also, Google it yourself and search we bay with the part number too.
Dec
They look similar to those on an SL door, and you can carefully prise them out, they give access to wiring connectors. Dec is spot on, they should have a part number on them somewhere, usually 10-11 digits, then try to source a good replacement on ebay that matches.
ok, how do I find it?
Maybe should mention that not all ebay sellers list the part number in the title, so it might be an idea to search for door card trim, door panel cover trim, and similar wording, that way you'll have a better chance of finding more options.
It might be just a cheap from your local Mercedes dealer, worth a call.
Dec
Have you tried Newcastle MB on eBay? They have genuine MB parts obviously, normally at a lower cost than your local dealer. I’ve used them a couple of times now... delivery within a day or 2, good service so far ;)
You can also call them direct and ask for the part... I did this 2 days ago to get some (missing) smaller wheel bolts for the space saver spare wheel. The guy knew the part and gave me the number. They arrived today.
