John20
Hi guys,
So I'm in the process of trying to replace the rear right passenger door's lock/actuator. Guides online are unfortunately all seemingly for the front door and different vehicles so a lot of the process is almost the same... but there are bits that are different and so far.. I'm stuck. I've managed to get the trim off, the various cables and things all disconnected and I've removed all the rivets holding the metal panel in place. This is where I'm stuck. These guides refer to removing the external door handle using a screw from inside the door where the rubber seals are however , as shown in the video I've attached. The only hole I find is seemingly empty?? the driver's door, you insert the screw driver maybe 2cms in and you're hitting the screw. The rear doors (I checked both) aren't the same and you can visibly see nothing at all inside the hole. You put the screw driver in and you can wiggle it around and there's nothing. I do at one point feel something... quite a way inside but nothing like a screw but its hard to tell.
I've posted a video which willl hopefully explain in more clear detail and I hope someone can advise!
