Hi all
I'm pretty new to the Mercedes scene, my Girlfriend has just bought a 2005 C200 CDI, Every now and then it goes into what i presume is limp mode, it will not rev above 2500rpm and the auto box will not down****f. We put it on my friends snapon scanner and it says the DPF content is too high, then fault code 1664 item number n33/2 heat booster control module no signal, another fault it lists is all 4 heater plugs but i've forgot the code. We regenerated the DPF and added some cleaner to the fuel, where is the heat booster and control module on these cars? oh yeah, the engine check light seems to be missing from the dash too so
