steve pratt
- Jan 22, 2016
- c200 kompressor estate
Hi, just a heads up that having read previous posts i can confirm that the scuffing noise that i had coming from the passenger foot well area did turn out to be the common fault of the hand brake cables having come un clipped and dragging on the prop shaft. The blue clips were intact but the semi circular metal clip at the rear hidden behind the heat shield holding a conduit was un clipped. Easy fix.
