Mar 17, 2023 #1 Modmans24vv6 Member Joined Jan 22, 2023 Messages 38 Location Derby Car Cls 350 Before I use brute force and break something, does the main drivers window switch just pull out, or do I need to remove the door card, the rear 1 just pulled out.
Mar 19, 2023 #2 Muckypaps Active Member Joined Jun 17, 2018 Messages 535 Location Barnsley Car CLS63s 2016 There is a Torx T20 screw on the inside of the door card which looks like it could be holding the switch panel in.
Mar 19, 2023 #3 AMGeed MB Club Veteran SUPPORTER Joined Nov 1, 2008 Messages 19,758 Location Bournemouth/Poole Dorset Car W210 E280 x2, w211 E55, W212 E63 biturbo, S204 C180K As above, if its like the E class, the front door card needs to be removed to gain access to the window switch
Mar 21, 2023 #4 OP OP Modmans24vv6 Member Joined Jan 22, 2023 Messages 38 Location Derby Car Cls 350 Thanks, the rear just pulled out, even if it wasn't ment to lol, glad I didn't just try the same on the front
