After changing injector & fuel filter on a C220 cdi (as I had the P0269 DTC) it is still shuddering on idle and the injector (that cost £160!!) made no difference also the check engine light came back on yet again saying P0269.
I have now checked everything and happened to notice that when the fuel rail pressure sensor is unplugged the car runs 100% but cannot rev above 3000 rpm
I would change it but i doubt that it is the problem (and at £150 i didn't want to risk buying another useless part) because the DTC would surely indicate that the FRPS is at fault or at least have a contribution error to all 4 cylinders
even when plugged in the symptoms don't come back until i stop and start the engine again
i have also noticed that the engine has to be at normal running temperature before the shuddering starts
I have a video on YouTube to show exactly whats happening ( https://www.youtube.com/watch?v=nBMCzr_tWlQ&feature=youtu.be )
Any suggestions/advice would be greatly appreciated
Thanks in advance
Thanks in advance
