HITECH
Hi, thankfully this isn't my car. My m8 whoes got a c220 04 plate had his car go into limp mode intermittently and his engine light came on. So we swapped for few days so I could try get to the source. Code that came up 1st read was p1402 (EGR blah blah....). So I cleared the code and turned engine light off. Took EGR valve off and thoroughly cleaned it. Also cleaned as much of the port as I could. Put it back on and took it for a thrashing. Was good for that day. Following day it was scorching and I done bout a 20 mile drive at high speed (within speed limit of course ) then it went into limp mode. So I pulled over plugged reader into it and it was 1402 again. So I cleared it started up and it was OK. Maybe 10 minutes later after parking n switching off I get back in start it n its in limp mode again. So I drove off and while driving switched the ignition off n bumped started it again in 4. This kicked it out of limp mode and it was fine til the 20 mile journey home. Done it again. By this time engine is running warm again so its a warm engine issue I've established NOT COLD. So to rule the EGR valve out I swapped it with my own from my own car which is 100% fine. I have no problems at all with mine. His car does the same thing with my working EGR from my car in it. So swapped back over put his own back in. I've checked wiring its all fine. He hasn't had a service in just over a year now. Would an oil change make any difference since his oil defo needs changing out now. No issues with coolant or engine temps or in car heater or oil or water mixing so fine there. Any idea where I go from here.not had to investigate Dpf problems before so if I have to go down that route its new ground for me. Would really appreciate some input guys. I've searched around on here but not found any working fixes as yet. Thanx in advance.
